Hi all
I am having a problem with a cross section of the column changes
this imange
http://nl0.upanh.com/b1.s29.d1/8e962d4a0d618a4cc785964418104722_44001610.col.bmp
I look forward to your help
thank all
yeah thank you
I want you to help me how to define columns with section changes in robot
thank so much
yes good too
I thank you very much look forward to learning from you
you have sent me documents about robots ameliorated
my mail address:duchoatla@gmail.com
please anyone have a computational model of industrial frame
send me the reference
I sincerely thank
mail: duchoatla@gmail.com
Try to define horizontal offset at the top of the column. Mind that a bar element is just the line that represents the center of the section with assigned attributes such as profile type.
The other option is just move the top node towards the middle of a frame. See the frame model attached to http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Design-colum-Steel-of-Robot/td-p/3562338 (message 10).
