I can not understand this message:
at which point I have to read the rules?
thanks
Solved by Artur.Kosakowski. Go to Solution.
Hi Andrea,
I'm sorry but I'll need a bit of time to check this.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
In RSA 2017 the error displays additional references to the corresponding paragraph of the code:
Calculations of attached column give warning: column's width =30cm does not satisfy the rule >=30.1(cm).
for DM2008:
(DM 14/01/2008, 7.4.6.1.2)
for EN8:
(EN 1998-1:2004, 5.2.3.7 (2)P a))
