I'm working on a workflow that transfers reactions from a column (mainly Fz) for the time being and transfer the information into Revit.
Currently the results come into Revit through the Results explorer, but I'm looking for Instance/Shared Parameters values that are linked to the column.
I'm looking to complete internal calculations from the results we get back from Robot.
Matt
Solved by Rafal.Gaweda. Go to Solution.
I'm aware of the results in the explorer, see my original post attachment.
What I'm looking for is a way to get the values attached to the instance properties of the column. The "results" don't attach to the Revit geometry or Analytical lines, they are only shown in the Results Explorer.
When I select the Column or Analytical column I don't get the information in the instance properties of that object.
It only appears after I have applied through the Results Explorer and is display only values.
I'm looking to use the value in a calculation in the Column family.
As I wrote before - not possible.
Sorry I didn't see the "not possible" before.
So the results are "display" only?
If they are more than that, I can try and use the API to retrieve the results. Or is this not possible as well?
