Message 1 of 17
Romanich
1681 Views, 16 Replies
Column head
What is a best practice to model column head in Robot?
I know some:
  1. Make hole in plate and insert plate with another thickness
  2. Select FE and define plate with new thickness
  3. Use rigid links
Also, I’m trying to use FE thickness variable along line, but it very no handy.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
16 REPLIES 16
Message 2 of 17
Artur.Kosakowski
in reply to: Romanich
As you wrote Smiley Happy . Or if this is only for punching check add this info in the RC Slab Design module only.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 17
Topic good.
You can tutorial step 3: use rigid link.
I is attachment file.
Message 4 of 17
Artur Kosakowski
Message 5 of 17
HI. thank you.
But why show slab Punching????????
Thank agian
Message 6 of 17
This approach is not intended for verification of the punching. In such case you should decide on one of these instead:
  • Make hole in plate and insert plate with another thickness
  • Select FE and define plate with new thickness
  • Or if this is only for punching check add this info in the RC Slab Design module only
In addition make sure you defined either a 'real' column (bar) under a slab or a support with the determined size (advanced properties of the support) and you do not have any beam in this location. This is necessary for the correct detection of the punching verification points.
Artur Kosakowski
Message 7 of 17
Thank you is reply.
Can you give me an example of "Or if this is only for punching check add this info in the RC Slab Design module only".  ???????????????
Message 8 of 17
Here you are
Artur Kosakowski
Message 9 of 17
THanks
You can send modol for me???.
Please .......
Thanks.
Message 10 of 17
Artur Kosakowski
Message 11 of 17
HoshangMustafa
Hi @Romanich
You wrote:
  1. Select FE and define plate with new thickness
Can you elaborate more on this?
I can select FE from Selection>> Finite element. Then what?
Message 12 of 17
HoshangMustafa
Hi @Romanich
any help would be highly appreciated.
Message 13 of 17
Romanich
in reply to: HoshangMustafa
Hi @HoshangMustafa,
Roman Zhelezniak
Message 14 of 17
HoshangMustafa
Hi @Romanich
highly appreciated.
Message 15 of 17
DonBAE
@Romanich be careful in your example video the TH25 panel elements where not removed when you placed the TH50 panel so there are two finite elements existing in the same location rather than distinct TH50 panel elements only.
I have asked the Autodesk representatives numerous times to provide an example of how to properly model drop panels with their software and have received no reply.
Message 16 of 17
Romanich
in reply to: DonBAE
Hi @DonBAE,
It seems everything is ok with finite elements:
Roman Zhelezniak
Message 17 of 17
DonBAE
perhaps this was just one of the numerous graphical glitches that occur in robot then as your video shows both panel definitions occupying the same location. I've experienced several models where the finite element mesh overlapped in these regions so the behavior does not seem to be consistent:
