Discussion Groups
Robot Structural Analysis
*Expert Elite* | International Moderator
Romanich
Column head
446 Views, 9 Replies
06-22-2012 01:07 AM
What is a best practice to model column head in Robot?
I know some:
  1. Make hole in plate and insert plate with another thickness
  2. Select FE and define plate with new thickness
  3. Use rigid links
Also, I’m trying to use FE thickness variable along line, but it very no handy.
Please use plain text.
Product Support
Artur.Kosakowski
Re: Column head
06-22-2012 01:10 AM in reply to: Romanich
As you wrote :smileyhappy: . Or if this is only for punching check add this info in the RC Slab Design module only.
Artur Kosakowski
Distinguished Contributor
A.wikipedia
Re: Column head
10-02-2012 08:48 PM in reply to: Artur.Kosakowski
Topic good.
You can tutorial step 3: use rigid link.
I is attachment file.
Product Support
Artur.Kosakowski
Re: Column head
10-02-2012 11:33 PM in reply to: A.wikipedia
Artur Kosakowski
A.wikipedia
Re: Column head
10-03-2012 12:05 AM in reply to: Artur.Kosakowski
HI. thank you.
But why show slab Punching????????
Thank agian
Product Support
Artur.Kosakowski
Re: Column head
10-03-2012 12:17 AM in reply to: A.wikipedia
This approach is not intended for verification of the punching. In such case you should decide on one of these instead:
  • Make hole in plate and insert plate with another thickness
  • Select FE and define plate with new thickness
  • Or if this is only for punching check add this info in the RC Slab Design module only
In addition make sure you defined either a 'real' column (bar) under a slab or a support with the determined size (advanced properties of the support) and you do not have any beam in this location. This is necessary for the correct detection of the punching verification points.
Artur Kosakowski
A.wikipedia
Re: Column head
10-03-2012 01:04 AM in reply to: Artur.Kosakowski
Thank you is reply.
Can you give me an example of "Or if this is only for punching check add this info in the RC Slab Design module only".  ???????????????
Product Support
Artur.Kosakowski
Re: Column head
10-03-2012 01:29 AM in reply to: A.wikipedia
Here you are
Artur Kosakowski
A.wikipedia
Re: Column head
10-03-2012 01:32 AM in reply to: Artur.Kosakowski
THanks
You can send modol for me???.
Please .......
Thanks.
Product Support
Artur.Kosakowski
Re: Column head
10-03-2012 01:46 AM in reply to: A.wikipedia
Artur Kosakowski
