In the column note for "provided reinforcement"I only see my static loads and no seismic (ACC) load cases, although they have been defined and used in the analysis and calculation of required reinforcement.
Solved by Rafal.Gaweda. Go to Solution.
I delect the seismic loads in the Parameters dialog alright, but they don't show up in the RC model.
Which robot version do you use?
Which RC code?
Any chance to upload the file?
RSAP 2012.
The file size is huge over 100MB
Codes attached
