Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Column-beam (two-sided) connection button disabled ?
3 REPLIES 3
corne_mo
1142 Views, 3 Replies
I am doing some manual connection analysis using the steel connection module of Robot Pro 2014.
In the New Connection toolbar I can select all connection types except the Column-beam (two-sided) connection, which button is disabled and grey coloured.
I however need this analysis type. How can I make Robot enable this button so I can do such an analysis?
Thanks in advance for your reply.
3 REPLIES 3
Artur.Kosakowski
in reply to: corne_mo
This connection type is available only for French CM66 code.
Artur Kosakowski
corne_mo
in reply to: Artur.Kosakowski
Eurocode asks for a check taking into account the interaction of both beams (mainly for web shear checks).
Is this incorporated in the single sided column-beam check by entering values for moments and forces for both b1 and b2?
Artur.Kosakowski
Yes, it is. If you check the calculation note  ( or use manual calculations of the connection) you can see the forces for both (left and right) beams. Mind that it is assumed that the beams are of similar sizes.
Artur Kosakowski
