Discussion Groups
Robot Structural Analysis
andrea.pontiggia
Coefficient of homogeneity for concrete structure
295 Views, 3 Replies
10-04-2012 10:43 AM
I wanted to know if you can change the value of the coefficient of homogeneity n (or m), for the calculation of concrete structures.
thanks
Andrea
Please use plain text.
Product Support
Artur.Kosakowski
Re: Coefficient of homogeneity for concrete structure
10-05-2012 12:27 AM in reply to: andrea.pontiggia
Which code and which point of the code do you mean please?
Artur Kosakowski
andrea.pontiggia
10-05-2012 01:06 AM in reply to: Artur.Kosakowski
Italian Code NTC 2008 par. C4.1.2.2.5 " Nei casi in cui si ritenga possibile effettuare un'unica verifica indipendente dal tempo, si può assumere un coefficiente di omogeneizzazione n fra i moduli di elsticità di acciaio e calcestruzzo pari a 15."
Andrea
Product Support
Artur.Kosakowski
10-05-2012 01:16 AM in reply to: andrea.pontiggia
Assuming that you want to introduce this change to EC2 design that of RC elements available in Robot then this is not possible. The ratio is calculated based on properties of selected concrete grade and steel.
Artur Kosakowski
