Discussion Groups
Robot Structural Analysis
Distinguished Contributor
2 Kudos
Code ??? INTERACTION DIAGRAM FOR SHEAR WALL
804 Views, 14 Replies
07-14-2012 02:30 AM
Hi. I don't see robot code caculation INTERACTION DIAGRAM FOR SHEAR WALL
Product Support
760 Kudos
Re: Code ??? INTERACTION DIAGRAM FOR SHEAR WALL
07-16-2012 12:14 AM in reply to: athurD
Such sort of results is not available for shear walls.
Artur Kosakowski
Valued Mentor
182 Kudos
07-16-2012 03:51 AM in reply to: Artur.Kosakowski
because you wouldn't design one for out of plane moment, hence the name shear wall
Active Contributor
17 Kudos
07-24-2012 11:44 AM in reply to: tony.ridley
That's a good question,
                                       It's time to ARSAP team to include this option in oder to complete the solution for seismic desing calculations, we can start by doing it for rectangular shape in a first time,and after for the other configurations. That would really help ARSAP users,still also waiting for RC desin of diferent shpae of pile cap in oder to complete de foundation design modulus.
2 Kudos
07-24-2012 12:14 PM in reply to: PatrickSt-Louis5310
Heloo.
I think Robot version 2014 is INTERACTION DIAGRAM FOR SHEAR WALL.
2 Kudos
10-12-2012 08:17 PM in reply to: athurD
Hi all.
I tried looking at the code, but I can not find documentation and formulas.
If you have any documentation about it, you can share to me?
Product Support
760 Kudos
10-15-2012 02:13 AM in reply to: athurD
If you are able to indicate any reference that describes the way of designing walls under bi-directional bending and axial force I would be much interested too :smileyhappy:
Such design is currently not supported in Robot.
Artur Kosakowski
2 Kudos
10-17-2012 11:08 PM in reply to: Artur.Kosakowski
Hi.Artur
I find the theory column. But I do not quite understand, the solution of the column.
you can provide theoretical royal adjust 3D calculated column???
Thanks.
Product Support
760 Kudos
10-18-2012 12:04 AM in reply to: athurD
I'm not sure if I understand your question. As far as I can see these formulas are for calculations of bending moments based on arm of forces (forces in each of reinforcement bars plus force in concrete) where z is the distance to the neutral axis.
Artur Kosakowski
2 Kudos
10-18-2012 12:13 AM in reply to: Artur.Kosakowski
Thank Artur.
I need the document (book , formula...) about  INTERACTION DIAGRAM FOR COLUMN 3D .
You can give me document  about it?
I was looking for, but it was too little.
Thanks.
