Discussion Groups
Robot Structural Analysis
Active Member
20086033
Accepted Solution
Code Group Verification Vs. Member Verification
447 Views, 3 Replies
10-19-2012 09:19 AM
There seems to be some inconsistency in the results between a member verification and a code group verification where the group only contains one member. See attached screenshots and calc. notes.
It looks like Robot for some reason changes the S275 material used in the member verification to some arbitrary material with a fy = 120 MPa in the code group verification.
Can someone explain if I’m doing something wrong here?
Please use plain text.
Active Member
20086033
Re: Code Group Verification Vs. Member Verification
10-19-2012 09:20 AM in reply to: 20086033
Product Support
Artur.Kosakowski
10-21-2012 11:27 PM in reply to: 20086033
Please make sure you have the correct material set in the group definition dialog.
Artur Kosakowski
Active Member
20086033
10-22-2012 02:54 AM in reply to: Artur.Kosakowski
Thank you for the quick response. That helped.
The code group was created through the API and apparently the material of the member is not set as default and you need to define it explicit.
Cheers
