Code group design - bug?
4 REPLIES 4
aruser
375 Views, 4 Replies
Could anyone explain me how this is happening?
Also, what does exactly mean this explanation taken from the help?..
"... optimization criterion is selected. If the sections of a profile in the current group belong to one family, there is no difference between the results obtained by means of the DESIGN option and those obtained with the DESIGN WITH OPTIMIZATION OPTIONS. Optimization functions as .."
4 REPLIES 4
Rafal.Gaweda
in reply to: aruser
Take a look at sections order
C150x2 then 150x2.5 but then next in database is 170x1.25 which gives such ratio.
Rafal Gaweda
aruser
in reply to: Rafal.Gaweda
yes, but then, shouldn't it have a red background??
what about the help explanation? could you please give me an example.
thanks
Rafal.Gaweda
in reply to: aruser
See below : code group design without optimization and design with optimization without criterion and design with optimization with Weight criterion gives the same results. Weight criterion is used as a default if nothing selected.
Rafal Gaweda
Rafal.Gaweda
in reply to: aruser
The idea is to show the best section ("OK"), the one previous (by name) not ok = "red", next (by name) with (usually) lower ratio ("green"). Display of red, green icon is assumed as decribed above, not related to real ratio that's why you can observe such effect.
Rafal Gaweda
