Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Code-control for HSQ (Beam for hollow core slabs)
1 REPLY 1
Hallvard
1354 Views, 1 Reply
Hi
I have been trying to do a control for a steel-beam accoridng to the design code. The cross-section is defined with data for webs and flanges.
The calculation of the model works fine, but when I try to calculate according to code Robot returns an error. Something like: "The cross-section does not fit the current code".
How do I make Robot perform code-calculations for custom cross-ssections?
1 REPLY 1
Rafal.Gaweda
in reply to: Hallvard
Hi
Open Tools \ Section Database viewer, load your database and check Shape Type comparing data with :
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-37C90ACA-0068-46B0-9CE2-76DEF8EED29-1630.htm
Set correct Section Type
Rafal Gaweda
