Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Code combinations
3 REPLIES 3
stroxy
6345 Views, 3 Replies
Code combinations
What is the difference between ACC, ACC+ and ACC-  (same goes for ULS, ULS+ and ULS-, as with SLS too). I understand somehow that they are the min and max values.  If that is the case, what values are displayed on say "diagrams for bars" when I select the ACC combination.
3 REPLIES 3
Artur.Kosakowski
in reply to: stroxy
These are the filters for top and bottom envelopes intended for the results displayed in the tables.
Artur Kosakowski
dimogrec
in reply to: stroxy
for example, open the force table -> global extremes, select a bar (if not all) and then choose the ACC cases to see how it works. First ACC-, then ACC+ and finally ACC...
e2009355
in reply to: stroxy
Could we use different codes in robot structural analysis to design one building? For example : material use eurocode (c25/30 for concrete) and deign use aci.
