Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
CODE COMBINATIONS COMPONENT SELECTION - Diagrams and steel analysis results
3 REPLIES 3
arailosotenet_gr
660 Views, 3 Replies
I might be missing something apparent here but I don't know what it is....
If you have a look at the attached images you'll see that
  • in the 1st image My (red box) in results is the expected value from diagrams but Mz (blue circle) is not the same
  • in the 2nd image Ned = Fx(loc) is not the same as in diagrams but Vz = Fz(loc) is the expected one.
3 REPLIES 3
Could you send the rtd file please?
Artur Kosakowski
The cross section I use for the columns is a user defined...Please let me know if you need ruserpro.xml file as well.
Please select the correct component of the code combinations while comparing results.
Artur Kosakowski
