I might be missing something apparent here but I don't know what it is....
If you have a look at the attached images you'll see that
Solved by Artur.Kosakowski. Go to Solution.
The cross section I use for the columns is a user defined...Please let me know if you need ruserpro.xml file as well.
Please select the correct component of the code combinations while comparing results.
