Discussion Groups
Robot Structural Analysis
Active Contributor
arailos
CODE COMBINATIONS COMPONENT SELECTION - Diagrams and steel analysis results
290 Views, 3 Replies
07-09-2012 11:30 PM
I might be missing something apparent here but I don't know what it is....
If you have a look at the attached images you'll see that
  • in the 1st image My (red box) in results is the expected value from diagrams but Mz (blue circle) is not the same
  • in the 2nd image Ned = Fx(loc) is not the same as in diagrams but Vz = Fz(loc) is the expected one.
Please use plain text.
Product Support
Artur.Kosakowski
Re: Diagrams for bars and steel analysis results
07-09-2012 11:44 PM in reply to: arailos
Could you send the rtd file please?
Artur Kosakowski
Active Contributor
arailos
07-09-2012 11:54 PM in reply to: Artur.Kosakowski
The cross section I use for the columns is a user defined...Please let me know if you need ruserpro.xml file as well.
Product Support
Artur.Kosakowski
07-10-2012 01:49 AM in reply to: arailos
Please select the correct component of the code combinations while comparing results.
Artur Kosakowski
