Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
claddings error
3 REPLIES 3
753 Views, 3 Replies
claddings error
can somebody know why i can't create claddings?
i receive message "loads applied to faces without claddings will not be included in calculations"
thank you!
3 REPLIES 3
Artur.Kosakowski
You can convert them into curtain walls in the way shown on the attached picture but as you defined them as ACIS object which is not recommended for panels I would suggest to set the preferences as on the same picture, delete these objects, save the file under a new name, restart Robot, open the file and define them again as claddings.
Artur Kosakowski
in reply to: Artur.Kosakowski
there is a roof without concrete slab.
i need claddings just to put the uniform loads from snow, wind and permanent load.
Thank you Artur!
Artur.Kosakowski
The only difference between a cladding and a curtain wall is that you can apply self weight for the later based on the assigned thickness.
Artur Kosakowski
