can somebody know why i can't create claddings?
i receive message "loads applied to faces without claddings will not be included in calculations"
thank you!
Solved by Artur.Kosakowski. Go to Solution.
You can convert them into curtain walls in the way shown on the attached picture but as you defined them as ACIS object which is not recommended for panels I would suggest to set the preferences as on the same picture, delete these objects, save the file under a new name, restart Robot, open the file and define them again as claddings.
there is a roof without concrete slab.
i need claddings just to put the uniform loads from snow, wind and permanent load.
Thank you Artur!
The only difference between a cladding and a curtain wall is that you can apply self weight for the later based on the assigned thickness.
