Robot Structural Analysis
Valued Mentor
23 Kudos
Cladding
305 Views, 10 Replies
02-06-2013 07:57 PM
Hi
I drew contour and applied surface load instead of drawing cladding and applying surface load. Does it effect the results? Is my work wrong? Should I delete these and redraw it? or else...
Product Support
1,303 Kudos
Re: Cladding
02-06-2013 11:46 PM in reply to: HoshangMustafa
It is not possible to apply loads on contours.
If they are applied it means that such onbject is panel or cladding.
You do not have to redraw contours \ claddings.
Either you can apply panel properties with Curtain Wall model
or change panel or contour onto cladding from the right hand mouse menu:
Rafal Gaweda
Valued Mentor
23 Kudos
Re: Cladding
02-07-2013 06:06 AM in reply to: Rafal.Gaweda
Hi
Mine is Face instead of Cladding/Face. Is Face the same as cladding for distributing Floor surface load on the surrounding beams?
Product Support
1,303 Kudos
Re: Cladding
02-07-2013 06:33 AM in reply to: HoshangMustafa
I guess you are refereing to situation : clading with no loads : http://screencast.com/t/Dr9SDcIl
Rafal Gaweda
Active Contributor
5 Kudos
Re: Cladding
02-09-2013 03:36 AM in reply to: Rafal.Gaweda
pls help me.
Product Support
1,303 Kudos
Re: Cladding
02-11-2013 12:11 AM in reply to: 40ushek
PLease send me model
Rafal Gaweda
Active Member
0 Kudos
Re: Cladding
11-14-2013 01:53 AM in reply to: Rafal.Gaweda
I have a question regading claddings and forces that are applied to them. I have a wall and openings in it, which represent windows. Is it possible to set wind forces to claddings that will act on the whole wall including the windows area?
Because if I created a cladding to a wall there are also created openings in claddings just the same as in the wall.
Product Support
1,303 Kudos
Re: Cladding
11-14-2013 02:07 AM in reply to: chiper.shriper
wall = shell
opening = cladding
Rafal Gaweda
Active Member
0 Kudos
Re: Cladding
11-14-2013 02:11 AM in reply to: Rafal.Gaweda
Yes. thank you for the replay, this is a possible solution, but as long as wind load continiously changes from the top till the bottom of the wall is there another solution?
Product Support
1,303 Kudos
Re: Cladding
11-14-2013 02:21 AM in reply to: chiper.shriper
Rafal Gaweda
