Discussion Groups
Robot Structural Analysis
Valued Contributor
9 Kudos
cladding
388 Views, 5 Replies
10-10-2012 12:01 AM
I've created a cladding for a steel frame to distibute loads(see attached model) but I notice that the cladding is not doing its functions of distributing loads(I checked the deformation due to wind loads but the value is zero!). Did I miss something here?
Product Support
758 Kudos
Re: cladding
10-10-2012 12:37 AM in reply to: saclovitzky
You used the incorrect load type. In v.19 of Robot for claddings you should use surface on object type rather than FE one. In addition I changed the distribution method from the grillage to the trapezoidal and triangular one which produces better results.
Artur Kosakowski
Valued Contributor
9 Kudos
Re: cladding
10-10-2012 05:50 AM in reply to: saclovitzky
Hello Artur,
I used surface loading in v19(surface/uniform planar load-x/y dir) but it doesnt work, but when I try the same model with
arsap 2012 it works fine, I do not know why it doesnt work in v19?
Product Support
758 Kudos
Re: cladding
10-10-2012 06:00 AM in reply to: saclovitzky
Looking at the load table you can see that the actual load type is (FE) uniform. This kind of load originally could be used for panels only but  in the newer versions we made the improvement allowing this type of load to be used on claddings too.
Artur Kosakowski
Valued Contributor
9 Kudos
Re: cladding
10-10-2012 06:33 AM in reply to: saclovitzky
Hello Artur,
"You used the incorrect load type. In v.19 of Robot for claddings you should use surface on object type rather than FE one. In addition I changed the distribution method from the grillage to the trapezoidal and triangular one which produces better results."
Waht do you mean of "use surface on object type rather than FE one" can you further explain this technique for v19?
Also, see attached screenshot to augment my question.
Valued Contributor
9 Kudos
Re: cladding
10-10-2012 06:45 AM in reply to: saclovitzky
Thanks Artur ,I already got it!
