Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Cladding option
13 REPLIES 13
Message 1 of 14
giyotd
602 Views, 13 Replies
Cladding option
I am trying to use the cladding option but there are some points that i didnt understand in the help :
What is the difference between these 3 types of load distribution (if i have uniform load on my floor which type should I use)
The list field displays 3 available types of load distribution based on the load direction:
  • Two-way - isotropic
  • One-way X - anisotropic: parallel to the local x axis of a panel
  • One-way Y - anisotropic: parallel to the local y axis of a panel and perpendicular to the local x axis of a panel.
2) i couldnt ubderstand what's the problem of the truss with cladding (" Use the Do not take truss bar into account option by selecting objects on which loads from               a cladding are distributed.")
Note The trapezoidal and triangular method is used to distribute loads for all cladding types. Because distribution methods are limited to this method, you cannot define               new types of load distribution. Use the Do not take truss bar into account option by selecting objects on which loads from               a cladding are distributed.
George
13 REPLIES 13
Message 2 of 14
Rafal.Gaweda
in reply to: giyotd
Re1 What don' you understand?
Re2 What don' you understand?
Start with:
http://forums.autodesk.com/t5/forums/searchpage/tab/message?page=1&location=forum-board%3A351&q=clad...
Rafal Gaweda
Message 3 of 14
giyotd
in reply to: Rafal.Gaweda
hey Rafal,
I have a one way deck slab in the X direction,
so what i have done is using clading with the load distribution in the x direction.
but after checking the results i figured out that some trusses have a very low axial forces comparing to others (like bar 268,332,488,479) in my robot file below.
http://www.filemail.com/d/nxunnmzukyvbfaa
George
Message 4 of 14
Rafal.Gaweda
in reply to: giyotd
No you did not
Even if you set One-Way-X please check local CS of cladding.
Almost all of beams are not parallel to local X of cladding so they will be loaded
Rafal Gaweda
Message 5 of 14
giyotd
Can you give me a hint what to do
Message 6 of 14
Rafal.Gaweda
in reply to: giyotd
Maybe you want this:
Rafal Gaweda
Message 7 of 14
giyotd
Rafal ,
I have done what you requested, but my question is why on certain truss bars like (268,332) the axial force is very low comparing to others
Thanks again for your help
George
Message 8 of 14
giyotd
in reply to: giyotd
Message 9 of 14
Rafal.Gaweda
in reply to: giyotd
Your model is inaccurate
1 delete all meshes
2 correct nodes coordinates as shown below:
Nodes  105 106 117 302 306 331 437 438  should have  Y=351,38010
Nodes 19 20 56 103 104 116 519to525 should have    Y= 338,45950
Nodes 23 24 58 101 102 115 should have  Y=311,61050
Nodes  27 28 59 97 98 113 257 263 284 289 298 305 318 452to462   should have Y= 299,69429
Nodes  29 30 33 34 60 61 242 245 247 251 256 262 269 288 293 439to451 should have  Y=290,37611
Nodes 331 437 438  should have  X =197,37518     Y=351,38009
Node 60 coordinates : X=187,99256         Y=290,37611       Z=21,87500
Add nodes on crossing points as indicated on screen shot below
mesh model
Corrected model for v.2015 attached
Rafal Gaweda
Message 10 of 14
giyotd
Thanks Rafal for your help
Message 11 of 14
giyotd
 Hey Rafal,
I am facing the same problem on some beams number(231,213,209,204,199,337,225,345,16,19,189) i am not having bending moment (My) on these beams
I have tried the  fix the nodes as you have mentioned before but it didnt work,
i would really appreciate if you can help me also this time
http://www.filemail.com/d/kqstrcpewqeahlp
George
Message 12 of 14
Rafal.Gaweda
in reply to: giyotd
Update your Robot with Sp4
Rafal Gaweda
Message 13 of 14
giyotd
is it better to update it to this version or 2014,
since my company didnt buy yet 2015 version
regards,
George
Message 14 of 14
Rafal.Gaweda
in reply to: giyotd
Your choice but it is always better to use the newer possible version.
If you will use 2014 please update it with the latest SP also.
Rafal Gaweda
