Hi, I am having trouble with the member on the screenshot taking a distribution of loading.
I have tried a detailed correct with structure correct to grid, making sure it is being analysed and changing the panel points and I cannot get it to work.
Could you please advise other checks to do. I will forward model if required
Solved by Rafal.Gaweda. Go to Solution.
Apologies Rafal,
Please see attached model file.
Enda,
In case of unidirectional distribution there is an assumption in algorithm not to load some members (rafters) if the angle is small - look at screen shot below.
Of course this load which should be generated on such member is distributed on others.
Hi Rafal,
Thanks for the reply, however my query is on the column member on the lower section of the building.
As you can see from the picture there is no load being distributed to this column. Would you be able to have a look please.
Enda
Correct your model
move node 179 onto 2723 then correct Y coordinate of this node and cladding point as indicated below
