Discussion Groups
Robot Structural Analysis
BertelliMarco1095
CLADDING AND LOAD DISTRIBUTION
1382 Views, 13 Replies
05-30-2012 03:05 AM
Dear all,
I use the cladding feature froms its addition in robot and is very usefull.
Today I was designing a rectangular slab with in the cernter a circular hole. I added a rectangular cladding and then a circle: you see on the screen that the circle forms an hole on the cladding. after the calculation if I look the the load ridistribution, i see that the hole is not considered! if I check the reaction the give the same result!
is this a bug or my procedure is worng? PLease find attached the example file.
Please use plain text.
Member
boele035
Re: CLADDING AND LOAD DISTRIBUTION
05-30-2012 03:13 AM in reply to: BertelliMarco1095
You didn't add the RSA-file to your question so I hope I did understand your question correctly.
I think you must ad the whole in your cladding as well.
greeting,
Henk Boelens
Product Support
Rafal.Gaweda
05-30-2012 04:27 AM in reply to: BertelliMarco1095
It should work. If not please attach example.
Rafal Gaweda
BertelliMarco1095
05-30-2012 05:47 AM in reply to: boele035
now the file should be attached
Product Support
Artur.Kosakowski
05-30-2012 06:20 AM in reply to: BertelliMarco1095
The distribution algorithm is not capable of correct detection of openings that stretch up to the edges of a cladding itself. You should either create two claddings and no opening or reduce its size.
Artur Kosakowski
BertelliMarco1095
05-30-2012 06:27 AM in reply to: Artur.Kosakowski
ok
thanks very much
Active Contributor
jamalsid
08-21-2012 02:33 AM in reply to: BertelliMarco1095
Hi
how did you get the load distribution pattern to display like that?
Product Support
Artur.Kosakowski
08-21-2012 02:40 AM in reply to: jamalsid
Artur Kosakowski
Active Contributor
jamalsid
08-21-2012 02:41 AM in reply to: Artur.Kosakowski
Wow, that was a fast reply!!
Thanks, knew it would be something simple.
gabrielhabib89
05-04-2013 07:51 AM in reply to: jamalsid
hey,
I am having problems with load distribution on the inclined roof, I added a load on the cladding but it is not distributed on the pannels. I put the load distibution in the right direction as seen in the attachement. It is working for the cladding on the columns.
Gabriel Habib
