Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Claddding panels reducing reactions
4 REPLIES 4
383 Views, 4 Replies
I have an issue with one of my models whereby when I add cladding panels to the structure, the reactions from a single load type reduce (by about 7%).
Can you please explain the cause and if there is a way to rectify this problem?
The panels also do not distribute its own load in a uniform manner (i.e. they are set to one way distribution but the distribtuion regions are irregular).
Thanks.
Tags (2)
4 REPLIES 4
Rafal.Gaweda
File please.
Rafal Gaweda
in reply to: Rafal.Gaweda
Rafal.Gaweda
workaround : all edge loads on edges on\over the claddings edges should be replaced by Linear Load 2p
Rafal Gaweda
Thank you for your swift response Rafal.
