I need design a circular slab with stiffener, could you give some advice how I do that
Please see attachment,
David
Solved by Artur.Kosakowski. Go to Solution.
There are two options I can think of:
1. Model the circular plate as a horizontal panel and add flat bars as bar elements (I would not define any offsets but I would change their moments of inertia if necessary)
2. Model the circular plate as a horizontal panel and add flat bars as vertical ones
