Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Check SLS Eurocode cracking with seismic load
3 REPLIES 3
andrea_pontiggia
704 Views, 3 Replies
Do I have to verify cracking with seismic combinations. The law is the Eurocode with attached French.
Robot apparent, subsequently cracking only (real armor) with SLS conditions and not with ACC.
How do I add also the combinations ACC checks relevant to the SLS?
thanks
Andrea
3 REPLIES 3
You can manually create such SLS combinations as shown on the attached picture.
Which part of EC2 or EC8 covers the calculations of cracks for earthquake situation?
Artur Kosakowski
It is actually a request from my client ...
I tried to do differently (see attached image), or changing the chart type combinations.
What do you think?
thanks
Andrea
The way you assign the type of combination should not matter. This should work in the same way too.
Artur Kosakowski
