Discussion Groups
Robot Structural Analysis
andrea.pontiggia
Check SLS Eurocode cracking with seismic load
411 Views, 3 Replies
01-11-2013 07:39 AM
Do I have to verify cracking with seismic combinations. The law is the Eurocode with attached French.
Robot apparent, subsequently cracking only (real armor) with SLS conditions and not with ACC.
How do I add also the combinations ACC checks relevant to the SLS?
thanks
Andrea
Please use plain text.
Product Support
Artur.Kosakowski
Re: Check SLS Eurocode cracking with seismic load
01-14-2013 12:08 AM in reply to: andrea.pontiggia
You can manually create such SLS combinations as shown on the attached picture.
Which part of EC2 or EC8 covers the calculations of cracks for earthquake situation?
Artur Kosakowski
andrea.pontiggia
01-14-2013 12:54 AM in reply to: Artur.Kosakowski
It is actually a request from my client ...
I tried to do differently (see attached image), or changing the chart type combinations.
What do you think?
thanks
Andrea
Product Support
Artur.Kosakowski
01-14-2013 02:38 AM in reply to: andrea.pontiggia
The way you assign the type of combination should not matter. This should work in the same way too.
Artur Kosakowski
