Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Check of existing concrete structure
3 REPLIES 3
TorgrimO
392 Views, 3 Replies
Is there a way to check an existing concrete structure to see if the reinforcement in it is sufficient? If so how do I do it? I have been trying to get the "Provided reinforcement" module to work, but I am not able to make much sense of it.
3 REPLIES 3
Artur.Kosakowski
in reply to: TorgrimO
To do so you first need to generate existing reinforcement. You can define loads and then design a beam / column to have reinforcement distribution. Then you can edit it and run verification. You can also try to use the typical reinforcement option for generation of reinforcement instead.
Artur Kosakowski
TorgrimO
in reply to: Artur.Kosakowski
How do I generate existing reinforcement for slabs? And I am currently on 2013 version of Robot (if there are differences in the procedure).
Artur.Kosakowski
This is currently not possible however you may consider another approach. If you run calculations of reinforcement you can compare obtained values of required area of reinforcement with the existing reinforcement in given locations of the slab. This should give you the estimation of the situation.
Artur Kosakowski
