Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Check if the sum of resistances of columns is greater than the beams
5 REPLIES 5
mjoflor
609 Views, 5 Replies
How can i check the next
 check if the sum of resistances of columns is greater than the sum of resistances of beams (increased by the coefficient g)
thanks
@mjoflor I edited the topic from 'Check if the sum of resistances of columnns'  for better findability and marked posts as the solutions. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution. Artur Kosakowski
5 REPLIES 5
Artur.Kosakowski
in reply to: mjoflor
Please check
http://docs.autodesk.com/RSAPRO/2014/ENU/filesROBOT/GUID-25441D9E-85F9-4F15-9726-6072E76845CA.htm
Artur Kosakowski
mjoflor
in reply to: Artur.Kosakowski
Ok thanks but do you post a example please????
Artur.Kosakowski
Here you are.
Artur Kosakowski
mjoflor
thanks for all
kostismanakashis
Hi @Artur.Kosakowski  @mjoflor
I have read the linked that you have posted regarding weak beams - strong columns.
I am trying to find out the window of "Node Geometry" in order to carry out the check but I can not find it.
I have change the designed codes to ACI and EC2 but I can not locate the "Definition in the Beam-column nodes module".
Could you please guid me how to access it?
Thank you very much.
