Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Charges sur radier
4 REPLIES 4
BESPOSTY
402 Views, 4 Replies
Charges sur radier
Bonjour,
Lors du maillage de la plaque (radier) du fichier joint, le système s'arrête à 76% sur "application des charges".
Que faire pour pouvoir continuer le calcul ?
Merci
4 REPLIES 4
jenyzosin
in reply to: BESPOSTY
You need to increase discretization and some restrains.
You need to add loads as liniar loads 2p on surfaces.
There's a fine line between genius and insanity. I have erased this line - O.L.
Rafal.Gaweda
0.3m FE size on 175m long plate will produce > 200000 FEs
0,5m -> 89000
1m -> 20000 - I suggest this one:  https://www.filemail.com/dl.aspx?id=RRXOXRHSZNIFILL
Rafal Gaweda
Rafal.Gaweda
in reply to: Rafal.Gaweda
MOre than 15 minutes to mesh it with 0.3m
Rafal Gaweda
BESPOSTY
Merci,
Je viens de constater l'erreur d'échelle : 17,5 m et non 175 m !!!
Merci de votre clairvoyance ..  😉
Bien à vous.
