I can't figure out how to change the label names of steel sections. It seams like this should be easy. I went into the "Label Manager" and there doesn't seam to be a way to rename the section names. I imported a model from Revit and the imported steel sections don't have a space in the name where as the sections imported from Robot do. It makes it hard to change bar sections as they are sorted wierd with the space.
Solved by Rafal.Gaweda. Go to Solution.
Hi
Select the label from right pane, click on < (this will make the label be available on the left pane, select the label in the right pane, rename it and click on > (this will make the lable be available on the right pane). please find the attached file.
