Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
amir57g
563 Views, 1 Reply
changing code
Hi,Is it possible to change and manipulate the Codes in Robot to adapt it with other country codes,For example to change the load coefficients?
2- for connections between a beam and culomn or braces,How can we assign the type of connection(pined,fixed) in Robot?
tnx
1 REPLY 1
Rafal.Gaweda
in reply to: amir57g
For EC based codes you can change this:
If you mean coefficients for automatic code combinations you can adjust it as you like selecting formulas, subnatures, and coefficients
tnx
Assign bars releases
Rafal Gaweda
