Hi,Is it possible to change and manipulate the Codes in Robot to adapt it with other country codes,For example to change the load coefficients?
2- for connections between a beam and culomn or braces,How can we assign the type of connection(pined,fixed) in Robot?
tnx
Solved by Rafal.Gaweda. Go to Solution.
For EC based codes you can change this:
If you mean coefficients for automatic code combinations you can adjust it as you like selecting formulas, subnatures, and coefficients
tnx
Assign bars releases
