Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Changes in RSA - Nodes with the same coordinates
10 REPLIES 10
Message 1 of 11
systemRobert
723 Views, 10 Replies
Greetings
Ive developed an external program for truss design a few years back, that wont work with RSA 2015 (at least not without modification).
Ive tracked down the problem to the fact that nodes and bars that have the exact same coordinates no longer merges when you run calculations.
Is it possible to reenable this functions in RSA?
Robert
10 REPLIES 10
Message 2 of 11
Rafal.Gaweda
in reply to: systemRobert
Maybe I did not understand your point....
Rafal Gaweda
Message 3 of 11
systemRobert
in reply to: Rafal.Gaweda
Hey, thats whats not working in my automated models anymore!
http://www.screencast.com/t/pC0mBkKs
The nodes are in the exact same place:
/Robert
Message 4 of 11
Rafal.Gaweda
It seems you have two rigid links there
one connecting node 8 or 14 with 12 and 10
another only in node 8 or 14
so 2 nodes with rigid links can not be merged
If it is not the case please send us model
Rafal Gaweda
Message 5 of 11
systemRobert
Well, yes you're right. However if I delete the non-connected rigid link, they will still not merge.
/Robert
Message 6 of 11
systemRobert
Crap! If I open it in recovery mode it works. Thats bad, since its my third party program that generates the model from the start.
Do you know some way to figure out what is wrong with the original model?
Message 7 of 11
Rafal.Gaweda
You have deleted RL fro slave nodes but not from master nodes as I suspected
Rafal Gaweda
Message 8 of 11
systemRobert
Yeah, but the problem persists. Even if you replace all the rigid links with short bars.
Message 9 of 11
Rafal.Gaweda
You have also "duplicated" supports there.
Remove supports from nodes 14 26 44 112 124 142
Rafal Gaweda
Message 10 of 11
systemRobert
Yes, this changed behaviour in RSA is what is causing this.
I'll dive deeper in our code to make our program handle the nodes in a more exact fasion.
Message 11 of 11
systemRobert
On second thought, isn't this a fault in Robot? If you open the model in repair mode, all nodes do get merged.
