Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Changes after repairing the model
10 REPLIES 10
Message 1 of 11
Ronald286
422 Views, 10 Replies
I repaired my model. After i run calculation, i got strange results. When i checked converted loads in dynamic analysis, i found strange things. Instead case 1(self weight - i ignore it in other tab) program defined case 0(see attached picture)! What else this program can change after repairing? Do I need to check all my loads and other things????
10 REPLIES 10
Message 2 of 11
Romanich
in reply to: Ronald286
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Error-message-quot-Encountered-an-improper-a...
In Russian:
http://www.rsa4all.com/2013/07/blog-post.html
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 11
Ronald286
in reply to: Romanich
Romanich, thanks a lot!
Message 4 of 11
Ronald286
Romanich, I did all according to your russian link. now it works worser(see attached picture). Now all cases defined as 0. I can't understand how this program works.
Message 5 of 11
Ronald286
so, we have a fact. Program creates huge number invisible nodes, which influence on calculation time and even on quality of the generated mesh(i check it). It is impossible to delete these nodes(support doesn't give solutions). I found a way to repair the model, in this case i can see this nodes and i can delete them. But in repaired model i lose a lot of information. And nobody can't say which information. This is a mistery! So, what i have to do? To make a new model??
Message 6 of 11
Romanich
Please save non-recovered file under new name without results, zip it and send to me.
Roman Zhelezniak
Message 7 of 11
Ronald286
Message 8 of 11
Romanich
Check attached file please.
Roman Zhelezniak
Message 9 of 11
Ronald286
See attached picture. This is printscreen from your model. Question - why load cases are changes? Another question - what other kinds of changes i can expect in my model?
Message 10 of 11
Rafal.Gaweda
Message 11 of 11
Rafal.Gaweda
Already corrected in Service Pack 3 for ARSA 2014
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22436870&linkID=13140816
Rafal Gaweda
