Dear all
Kindly find attached file ,robot model I have to change type of analysis from nonlinear to linear ,but I have no loads in case dialog in automatic combination ,pleas help
thanks
Solved by Artur.Kosakowski. Go to Solution.
For linear static you cannot set cases that you want to use in definition of a combination as auxiliary.
dear sir
i apply your suggestions , but model calcolation nonlinear anlysisi
kindly find attached file
dear sir
This is due to unidirectional boundary conditions you defined.
