Hi guys,
I know I can turn a panel into a cladding by going to geometry-->contour definition---------->check on the box "cladding/face"
Can I do this for multiple panels at a time? i.e. I want to select 50 panels, and change them all into claddings.
Tony
Solved by Artur.Kosakowski. Go to Solution.
No but you can change them into curtain walls instead. The only difference is the additional possibility to add self-weight for them. In case you don't want this (and you have automatic self-weigh for the whole structure) add self-weight Z+ load for them in addition to Z- for the whole structure.
Dim RSelection As RobotSelection Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_PANEL) RobApp.Project.Structure.Objects.SetLabel RSelection, I_LT_CLADDING, "Two-way"or
Dim RSelection As RobotSelection Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_PANEL) Dim PanelCol As RobotObjObjectCollection Set PanelCol = RobApp.Project.Structure.Objects.GetMany(RSelection) For ii = 1 To PanelCol.Count Dim o As RobotObjObject Set o = RobApp.Project.Structure.Objects.Get(PanelCol.Get(ii).Number) o.SetLabel I_LT_CLADDING, "Two-way" o.Update Next ii
glad to have you back - good holiday?
50/50 - wheather on our seaside is not perfect 😞
