I want to change the sense of local Z axis of a panel using Robot API.
I've searched the API help and I didn't found any method to do so.
It has a method to define the local X axis but not the Z axis.
Does anyone knows a way to do this?
Thanks in advance.
Solved by Artur.Kosakowski. Go to Solution.
Try to use the following code which changes the orientation of the Z axis for the panel number 1:
Dim r As New RobotOM.RobotApplication
Dim o As RobotOM.RobotObjObject
o = r.Project.Structure.Objects.Get(1)
o.Main.Attribs.DirZ = 1
o.Update()
Hi Artur,
Could you tell me how the z-axis and other axes (x and y)will be oriented if I use the snippet of code provided by you? I am unable to figure it out?
Thanks in advance!
Actually, I want my local coordinate axes for each panel to be such that the z-axis is always pointing outward.
Hi @rhlkochar
You have to check local Z vector and change it according to your needs
Dim RSel As RobotSelection Set RSel = RobApp.Project.Structure.Selections.CreateFull(I_OT_PANEL) Dim PanelCol As RobotObjObjectCollection Set PanelCol = RobApp.Project.Structure.Objects.GetMany(RSel) Dim X As RobotGeoPoint3D, Y As RobotGeoPoint3D, Z As RobotGeoPoint3D Dim Obj As RobotObjObject Set X = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D) Set Y = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D) Set Z = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D) Set Obj = PanelCol.Get(1) Obj.Main.Attribs.GetLCS X, Y, Z
Hi @rhlkochar
also, there is a syntax error with the following line:
o.Update()
This is C# code
In case of VBA : o.Update
Hi @rhlkochar
Hint:
o.Main.Attribs.DirZ = 0 'default (assigned by program) local Z direction
o.Main.Attribs.DirZ = 1 ' opposite to default direction
