Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Change Node Numbers
2 REPLIES 2
PaulGrimes2282
3289 Views, 2 Replies
Change Node Numbers
Is there any way to change the number assigned to a node? I have a spreadsheet designed to input all of my nodal data by cutting and pasting, but a couple of nodes are no longer correctly numbered for the spreadsheet and it mucks everything up.
For example i have a node numbered 86 in the model, with bars and properties attached, that i would like to be numbered 175. Is it possible without recreating the node and all the bars attached to it?
thanks!
2 REPLIES 2
Rafal Gaweda
thanks!
