Discussion Groups
Robot Structural Analysis
Active Member
zhurukhin
Change Analysis type to harmonic - not avaliable
292 Views, 3 Replies
12-28-2011 10:45 AM
Hi!
I want to change Analysis type for load number 13 from "Static linear" to "Harmonic", but this button is not avaliable (please, see attached file).
Modal analysis is done, results are avaliable. Besides that, I've already changed analysis type for loads 14 and 15. But for load 13 it doesn't work...
Thank you in advance
Please use plain text.
*Expert Elite* | International Moderator
Romanich
Re: Change Analysis type to harmonic - not avaliable
12-28-2011 10:58 AM in reply to: zhurukhin
Try to put Modal case before load case number 13.
Active Member
zhurukhin
12-28-2011 12:43 PM in reply to: Romanich
Thanks!
I'll try - if it's a solution, I'll inform you.
Product Support
Artur.Kosakowski
12-29-2011 01:30 AM in reply to: Romanich
Thank you for helping others.
The corresponding part of Help
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-47BF5B84-1D3B-49C8-AA62-F437868E221-704.htm
Artur Kosakowski
