Change Analysis type to harmonic - not avaliable
3 REPLIES 3
zhurukhin
585 Views, 3 Replies
Hi!
I want to change Analysis type for load number 13 from "Static linear" to "Harmonic", but this button is not avaliable (please, see attached file).
Modal analysis is done, results are avaliable. Besides that, I've already changed analysis type for loads 14 and 15. But for load 13 it doesn't work...
Thank you in advance
3 REPLIES 3
Romanich
in reply to: zhurukhin
Try to put Modal case before load case number 13.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
zhurukhin
in reply to: Romanich
Thanks!
I'll try - if it's a solution, I'll inform you.
Artur.Kosakowski
Thank you for helping others.
The corresponding part of Help
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-47BF5B84-1D3B-49C8-AA62-F437868E221-704.htm
Artur Kosakowski
