Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Center of torsion
1 REPLY 1
faisal.aaouatif
615 Views, 1 Reply
Center of torsion
When using the "Section definition"   module , is there any mean to compute the tortional center of a section (group of walls for ex).
Please find attached a calculation note of a typical section of stairwell / lift... (without the information ime looking for )
Thank you
1 REPLY 1
Torsion&shear center is calculated only when all segments (walls) are connected -see below:
Probably your walls are separated in points where you change their thickness.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
