Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Center of gravity, rigidity and mass
8 REPLIES 8
Message 1 of 9
sweapon
2274 Views, 8 Replies
Hi everyone
Where in robot can i find these information about a structure?
Center of rigidity
Center of mass
Kind regards
Alex
8 REPLIES 8
Message 2 of 9
Rafacascudo
in reply to: sweapon
Analysis menu /Calculation notes/ Full note
Rafael Medeiros
Message 3 of 9
Mohammed_Ata
From Results menu >> Stories >> Values' tab ... You will find table of G & R for each story .
This picture shows .
Message 4 of 9
And this is how you can view the centre of rigidity and centre of gravity on your model.
Results -> Diagrams for buildings -> Forces
Message 5 of 9
Hi, the checkboxes for center of gravity, rigidity and mass are locked to me in the table of Stories Results. Is it possible that I am missing something before calculations
Thank you for your help
Message 6 of 9
cdmatheus
in reply to: aimanalaawar
Hi @aimanalaawar
You need to define stories before calculations
Message 7 of 9
aimanalaawar
in reply to: cdmatheus
Thank you @cdmatheus, I had already defined stories but no worries I have known my mistake I did not see the values tab Man Embarassed
I have another question regarding residual mode for seismic calculation
I have made a modal analysis for a five story reinforced concrete building based on the UBC97 code
The mass participation for X & Y directions is about 73% and the frequency is about 33 (no significant change in these results from mode number 30 to mode number 40)
I have read that for such case residual mode should be used for seismic analysis, but it seems that it is not available for UBC97. What should I do in this case
Message 8 of 9
Hi @aimanalaawar
My assumption is that this question was answered by @mustafahesenow (thank you) in this topic:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/seismic-analysis-with-residual-mode-u...
Is this correct?
Artur Kosakowski
Message 9 of 9
Thank you @Artur.Kosakowski
