Hi, Can't find the way to export a reobot file into CBS
Anyone help?
Cheers,
Solved by Artur.Kosakowski. Go to Solution.
You can only export model from CBS to Robot. What the other direction is needed for?
hahah no idea really.
No, I like the way CBS does the column take down in a simple way and the reporting of column loads is nice.
Also saves me changing all the slabs to claddings to perform a "traditional" take down.
This seems rather easy. Select all slabs and change their calculation model in the Inspector.
