Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Cant open Robot Structural Analysis Professional 2012 (student version)
3 REPLIES 3
588 Views, 3 Replies
Hi so everytime i go to open up Robot Structural Analysis Professional 2012 (student version) it comes up with an error report and i cant open it, the same thing happens when i try to export to it from  revit structure. I have tried re installing it a few times to no avail and i have also tried downloading service pack 5 and ipv6 support upgrade but still no luck. My computer will not uninstall the software either which is a pain so I am stuck and do not know what to do. It was working fine a month or so ago but when i have used it lately it just doesnt work. Any advice or help would be greatly appreciated
James
3 REPLIES 3
Pawel.Pulak
Hi James,
please follow these steps:
1/ open Task manager and check for robot.exe processes still running - if running please close them
2/ delete the contents of folder
C:\Users\your_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2012\CfgUsr
3/ try to run Robot
4/ if Robot crashes and Customer Error Report window will be opened please specify your email address and sent the report - it would enable to identify it
5/ check the log file RSAPRO2012Adlm.log in the following folder:
C:\ProgramData\Autodesk\AdLM
Are any new records added to this text file in relation to point 3/  - check data and time. ProgramData is a hidden folder - changing explorer settings may be necessary to see it.
6/ where any new files created in CfgUsr folder I mentioned in point 2/
If steps 1/ and 2/ do not help please contact me using Private Message - remote access session may be the most efficient in this case.
Pawel Pulak
Technical Account Specialist
in reply to: Pawel.Pulak
well i deleted every file that had robot on it in my computer, then trying to re install it after i sent the error messages through to autodesk and it will extract all of the file for robot however it comes up with the installation page i dont have the option to click install, how do i get around this
Pawel.Pulak
Hi James,
please check Private Messages:private.png
Pawel Pulak
