Discussion Groups
Robot Structural Analysis
Valued Mentor
AJA14
can't add thermal loads
1058 Views, 2 Replies
11-29-2011 01:17 AM
I am trying to add thermal loads for bar elements. The problem is I can't find temperature or thermal loads in the new load type dialog. I've done it before but this time I can't locate it. If I open the load table and use the cell list, I can locate thermal loads. I even tried switching to different design and loading codes. Nothing happened. Any ideas.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Please use plain text.
Product Support
Artur.Kosakowski
Re: can't add thermal loads
11-29-2011 01:42 AM in reply to: AJA14
I'd say you look at the wrong dialog :smileyhappy:
Artur Kosakowski
Product Support
Rafal.Gaweda
11-29-2011 01:45 AM in reply to: AJA14
Natures displayed there are taken from Code Combinations settings (active code).
Go to Job Preferences, check Code Combinations
Rafal Gaweda
