Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
can't add thermal loads
2 REPLIES 2
AJA14
1298 Views, 2 Replies
I am trying to add thermal loads for bar elements. The problem is I can't find temperature or thermal loads in the new load type dialog. I've done it before but this time I can't locate it. If I open the load table and use the cell list, I can locate thermal loads. I even tried switching to different design and loading codes. Nothing happened. Any ideas.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
2 REPLIES 2
Artur.Kosakowski
in reply to: AJA14
I'd say you look at the wrong dialog Smiley Happy
Artur Kosakowski
Rafal.Gaweda
in reply to: AJA14
Natures displayed there are taken from Code Combinations settings (active code).
Go to Job Preferences, check Code Combinations
Rafal Gaweda
