I am trying to add thermal loads for bar elements. The problem is I can't find temperature or thermal loads in the new load type dialog. I've done it before but this time I can't locate it. If I open the load table and use the cell list, I can locate thermal loads. I even tried switching to different design and loading codes. Nothing happened. Any ideas.
I'd say you look at the wrong dialog
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Natures displayed there are taken from Code Combinations settings (active code).
Go to Job Preferences, check Code Combinations
