I want to analysis CFRP (Carbon Fiber Reinforced Polymerq) bands in addition to my RC 5reinforced Concrete) model. For that I need to add a new material or change properties of an existing material. I tried to find a solution but I could not so am asking u guys to help me in this regard. Thanks
@engr.sami Artur Kosakowsk marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution. i
Solved by Artur.Kosakowski. Go to Solution.
Job Preferences > Materials > press Modification button. Then type a new name, enter properties and press Add followed by OK. Finally restart Robot to make sure the new material is visible in all dialogs of the program.
ROBOT - Materials - How to create new materials
Hi @engr.sami
I just wanted to ask if you managed to define a new material following the steps I suggested?
And how can I swith to a different material on all my section bars and panels? I've already defined the new material but i'm looking for a way to change it quickly.
Thanks.
Select the desired material on the dropdown list ,then Select the bars you want to change material and click apply
Rafael Medeiros
Robot Structural Analysis
