Discussion Groups
Robot Structural Analysis
Active Member
AlexOpus
Calculations not completed - objects not in same plane
408 Views, 3 Replies
02-24-2012 07:32 AM
I've got a slab made up of several floor panels which I have successfully run reinforcement designs on before. I re-drew some of the panels and generated meshes succesfully, and run calculations, but when I try and run a 'provided reinforcement' design for the whole floor slab an error messgae comes up saying 'indicated objects must be lying in the same plane' . Does anyone know what this means and how to fix it?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Calculations not completed - objects not in same plane
02-24-2012 07:49 AM in reply to: AlexOpus
Please try to use Edit > detailed correct and adjust the structure to the single plane indicated by e.g. 3 corners of one of these panels.
Artur Kosakowski
Active Contributor
i.franco
05-20-2014 02:14 PM in reply to: Artur.Kosakowski
Good evening. I followed the procedure and the error keeps popping. Is there another way to correct this?
Model link:
https://www.dropbox.com/s/r0r19owdpi4j00t/715-03-01-001_0_1320-M3-SR.rtd
Thank you.
Product Support
Rafal.Gaweda
05-21-2014 12:12 AM in reply to: i.franco
Do not use ACIS panels or use Robot 2015
Corrected file : http://we.tl/iayQxnigcb
Rafal Gaweda
